vangeem Friend
vangeem
- September 2006
September 20, 2008 at 8:23 am #133539Hello,
I use joomla 1.5.7 + vm 1.1.2
The site is working very well but i’ve got one problem. On the home page i have the featured product module enabled, but sometimes (+- 1 out of 3 times) when you click on a product you’r not sent to products flypage but to main product page (where the manufacturers names are displayed). If you go back to the home page and re-click on the product your transfered correctly.
It’s quite annoyingI had this problem before i activated sef urls (using artio joomsef)
the site in question is : laptop-shop.be
Sherlock FriendSherlock
- 2478 times in 2162 posts
September 23, 2008 at 4:33 am #271788Hi vangeem !
I have checked your site , but coudn”t see problem , this is strange problem .shertmann Friendshertmann
- September 2008
- 42 times in 26 posts
September 23, 2008 at 4:52 am #271793well as hahn said i makle a review of your site and not see any kind of problem. maybe is related with one specific product?
vangeem Friendvangeem
- September 2006
September 23, 2008 at 3:18 pm #271906Hi,
I still got the same problem (happens 99% when i enter the site, on my first click).
Allready cleared cache of IE and it happens on 2 different machienes.The page i’m redirected to is: http://laptop-shop.be/producten-4.html?vmcchk=1
- September 2008
September 23, 2008 at 4:48 pm #271926really this is one extrange problem. when i make click the first time it appear but then no.
- September 2008
September 25, 2008 at 12:46 am #272165i check your site again and i did nothing
- September 2008
September 26, 2008 at 12:18 am #272356anyway vangeem did you make any modification to the original code?
- September 2006
September 26, 2008 at 6:26 am #272401<em>@shertmann 82149 wrote:</em><blockquote>anyway vangeem did you make any modification to the original code?</blockquote>
NO, but this topic can be closed … as it turns out it is a virtuemart or joomla core problem.
I found a post on the VM forum, i’m not the only one with the problem.shertmann Friendshertmann
- September 2008
September 26, 2008 at 7:11 am #272411well if you found the solution post it here in order to other can know how it can be fixed
- September 2006
September 26, 2008 at 7:18 am #272416there’s no real solution, this is the topic i was talking about
http://forum.virtuemart.net/index.php?topic=44495.0
I tried disabling the cookies in virtuemart, now the links were fine but the check-out process didn’t work anymore… so that’s not a good solution 🙂
This topic contains 10 replies, has 3 voices, and was last updated by vangeem 16 years, 3 months ago.
