  • wisdom114 Friend
    #682676
    I followed the documentation but still cant get the features intro to work properly.
    It looks like this but this is not what i want
    i want it to look like this
    I just want it to look like the demo version
    http://www.obligatoryknowledge.com
    Ninja Lead Moderator
    #682756
    Because the Advanced and JA Extra Fields tabs missed some parameters on that, you can follow my screenshot below and change the configuration on your site
    + Advanced
    + JA Extra Fields
    Hope it helps
    #748039
    + Advanced
    + JA Extra Fields
    Hope it helps
    wisdom114 Friend
    #683093
    It helped a little but it seems like the module suffix is not working. Check it out.
    wisdom114 Friend
    #748230
    #683664
    <em>@wisdom114 491635 wrote:</em><blockquote>It helped a little but it seems like the module suffix is not working. Check it out.</blockquote>
    Because you had to change position name Features Intro layout on your site, I just helped you to to change it back as our demo and disabled only masthead to none position
    Now, you can see it’s working fine on your site.
    #748422
    Because you changed position name in Features Intro layout on your site, I just helped you to roll it back as our demo and disabled the masthead by set it to none position.
This topic contains 7 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 3 months ago.
