  • Saguaros Moderator
    #1089269
    Hi Andrew,
    Kindly share the credentials of your site and tell me the module you’re trying to change the content, I will check for you.
    Andrew Winkler Friend
    #1089314
    Maybe due to the caches on your browser? as I can see the new text now: http://prntscr.com/i81w9d
    #1089462
    The "intro text" still does not show on my computer, Firefox, Edge or Chrome, regardless of whether I just change the module that comes with the template sample data or create a completely new one. I had a look at your screenshot and there the "intro text" is missing too.
    1. No-Introtext-Showing
    For the text block under the module title, you should update the text via the Extra Fields tab of module: http://prntscr.com/i8glbe
    I updated for you and it’s showing now.
    Kindly check.
    #1090066
    How do I close the ticket as solved?
This topic contains 6 replies, has 2 voices, and was last updated by  Andrew Winkler 6 years, 10 months ago.
The topic ‘Features Intro: Style-2 Introtext not changing’ is closed to new replies.
