April 15, 2008 at 3:00 pm #127579
hi,
I have joomla 1.5.2
I have this problems:
1) when I activate JA_NewsFlash modulu, the popup module is not working … any help?
2) I dont understand, how to make the image to be a link to the popup window? it will work only text link
3) in ie6 the end of the page is not correct, see atachment
4) I have problem with text coding and the style of the header od the popup window, see atachment1371
1372
thanks
April 15, 2008 at 3:08 pm #245594
the footer is not displaying correctly …
1373
on ie6 the homepaga link (the logo up right) doesnt work
April 15, 2008 at 4:21 pm #245600I have the same problem with the footer leaving a gap at the base.
April 15, 2008 at 4:40 pm #2456021) image as link for popup – it image should be setuped as category image
2) background problem in popup header – title-bg.gif is missing in your template, I have downloaded it from demo page2 problems still persists:
1) coding problem in header popup
2) footer display in ie6
3) colision with ja_newsflash moduleApril 16, 2008 at 9:34 am #245659Footer display problem with ie and firefox any ideas?
April 16, 2008 at 9:44 am #245660the last big problem I have is the header coding in popup window as shown i previous post with red arrow
April 17, 2008 at 2:45 pm #245789Nothing yet on how to fix the footer problem?
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 19, 2008 at 4:30 am #245981Hi nanettecowie.
Can you send your URLApril 20, 2008 at 11:19 pm #246134At present am just setting it up on a local machine to see how i like the template etc so its not hosted online same problem as above user was having.
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by nanettecowie 16 years, 8 months ago.
