  • tribalkg Friend
    #147489
    First of all, thank you for this great template. I found few problems with this template.
    1) For some reason, collapse function for modules is not working. Also, user controls for font size are not working too. But, when I go to MorfeoShow (image gallery) link and when I open gallery, collapse is working and user controls too. This isn’t all. When this start to work, image gallery doesn’t run images properly.
    I believe that there is some conflict between java scripts but I have no idea how to solve it. :confused:
    2) Second problem I found is with tables. When I insert table, left border isn’t showing when table is positioned to left. I’ve solved this by centering the table with margins set to auto, but it would be nice if there is a solution for this.
    This is web site that I’m talking about: http://www.wildboars.org.rs
    Image gallery is in the main menu on the left, “Galerija slika”.
    Thank you.
    jaybrd1 Friend
    #328826
    Maybe check and see if any of your addons offer you to NOT load mootools or jquery, or have an “auto” option.
    It may not work, but I have noticed that some addons will not work, or cause others not to work, the reason is that mootools is being loaded multiple times. Conflicts between addons will cause the problems you are having.
    tribalkg Friend
    #328842
    It was JCE Utilities. Uninstall of this plugin solved the problem with collapse function. There is still problem with MorfeShow image gallery. On other templates it works just fine but with Purity II doesn’t load pictures in LightBox pop-up.
    Thank you for your assistance.
This topic contains 3 replies, has 2 voices, and was last updated by  tribalkg 14 years, 10 months ago.
