  • etchot Friend
    #191976
    I want to include a filter in my website that allows a user to select one of the following values (number of rooms) from a drop down: 1+, 2+, 3+, 4+ or 5+. The result after applying the filter should be the same as using an ‘opened’ range. For example: if the user selects +3, all the houses with 3 or more rooms should be displayed.
    How can I configure the JA K2 Search Module to achieve the result mentioned above?
    Thanks,
    Etchot
    Luna Garden Moderator
    #511200
    Hello Etchot,
    <blockquote>The result after applying the filter should be the same as using an ‘opened’ range. For example: if the user selects +3, all the houses with 3 or more rooms should be displayed.</blockquote>
    In order to make the range as you requested:
    1. In K2 Extra Field, the Type of Extra Field should be Text
    2. In Module Manager of JA K2 Filter, choose the type to display is Value Range. You can see more as in this capture: http://easycaptures.com/fs/uploaded/808/2960257062.jpg
    The value in Range should be
    0|1|2|3|4|5
    etchot Friend
    #511218
    Hello Luna,
    Thank you for your quick answer. I followed your instructions but I am still not able to get the desired result. According to your answer what option in the drop down should I select to get all the houses with 3 or more rooms as a result of the filter?
    Regards,
    Etchot
    #511308
    Hello Etchot,
    Please follow my instruction in this link here: http://www.joomlart.com/forums/topic/filter-items-based-on-a-price-range-defined-with-two-drop-downs/#post-511260
    Range Slider is the exactly solution for your need, but it’s not a dropdown option, but a slider. Please check our demo of JA K2 filter for Range Slider here: http://demo.joomlart.com/joomla-extensions/ja-k2-filter/dynamic-counter (see the Price on the left column)
This topic contains 4 replies, has 2 voices, and was last updated by  Luna Garden 11 years ago.
