maikkeli Friend
maikkeli
- March 2009
- 2 times in 1 posts
May 6, 2011 at 5:38 am #163656I have a problem using IE and having Jobs Filtered by Location in which the Location uses ä ö letters.
Search Result ends up with 0Look at the Images named by used Browser.
Vinh CV Friend
Vinh CV
- August 2009
- 76 times in 72 posts
May 10, 2011 at 7:41 am #390516Hi maikkeli,
We have fixed on your site already. Please check again.
maikkeli Friendmaikkeli
- March 2009
May 10, 2011 at 11:40 am #390565<em>@vinhcv 239490 wrote:</em><blockquote>Hi maikkeli,
We have fixed on your site already. Please check again.</blockquote>
can You still check on this
when searching for “Projekti-insinööri” You will end in endless loop
instead searching only for “insinööri” will get results!And still the same Problem with IE9, only compatible mode works on simple jobs with no dashes
- March 2009
May 10, 2011 at 8:18 pm #390651site is online now – and ftp details are pointing to the test server
Vinh CV FriendVinh CV
- August 2009
May 11, 2011 at 7:03 am #390723<em>@maikkeli 239547 wrote:</em><blockquote>can You still check on this
instead searching only for “insinööri” will get results!And still the same Problem with IE9, only compatible mode works on simple jobs with no dashes</blockquote>
Hi maikkeli,
We have checked on your site, the search function still works with keyword “Projekti-insinööri”. Please check again.
- March 2009
May 11, 2011 at 3:32 pm #390808Can You please check here its online now:
The search is very very slow? Maybe tmp cache problem?
I have set chmod no help.Does the filter process trigger to many database calls so that the system somehow stops the requests?
Do I have to tell the ISP setup the service that way I can use Jobboard?!
- August 2009
May 12, 2011 at 7:12 am #390891Hi maikkeli,
We can’t access to the site http://www.stafflink.fi/, please check again.
The speed problem maybe caused by your network speed, your server performance.
Everything works fine in our demo site with search job function.
- March 2009
May 16, 2011 at 3:29 pm #391487I think You can now! Case solved by ISP without any comments.
- August 2009
May 17, 2011 at 7:23 am #391563<em>@maikkeli 240760 wrote:</em><blockquote>I think You can now! Case solved by ISP without any comments.</blockquote>
Viewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by maikkeli 13 years, 3 months ago.
