  • cloudtech Friend
    #203934
    I’m trying to fix the links on the letters after “Varemaerke-indeks” which are meant to redirect you to the relevant manufacturer(S):
    http://37.26.108.115/~jersildvin/2014-07-16-16-55-44
    When you currently click on a letter, after “Varemaerke-Indeks” it redirects you to “Vine” no matter which letter you click. Also, I’d like to get rid of the text “Varemaerke-indeks” and just leave the letters. Have tried looking for where I can do this but no luck so far.
    Cheers!
    This seems to happen in Mijoshop default also. I tried to switch default template to standard template of Joomla like Beez / Protostar but the same issue occurs.
    Could you please raise the same thread to mijoshop support?
    cloudtech Friend
    #560382
    Thanks, I will!
This topic contains 3 replies, has 2 voices, and was last updated by  cloudtech 9 years, 10 months ago.
