Viewing 4 posts - 16 through 19 (of 19 total)
  • Sherlock Friend
    #253166
    Hi jantonio
    Because JA often update version, so link file often change, but you can see all file to download HERE
    jantonio Friend
    #253253
    <em>@nguoiabcd 58578 wrote:</em><blockquote>Hi jantonio
    Because JA often update version, so link file often change, but you can see all file to download HERE</blockquote>
    Hello, Please take note that “com_rsgallery2_1.0_modified_by_ja.zip” is NOT under your package JA Avian II v1.2 for Joomla 1.5.x.zip.
    #253349
    com_rsgallery2_1.0_modified_by_ja.zip in package Ja Avian II 1.0 cho Joomla 1.0
    versaille123 Friend
    #253374
    <em>@hanhct 48007 wrote:</em><blockquote>@maxmmize:
    sorry, you can download the com_rsgallery2_1.0_modified_by_ja.zip HERE
    that link install for joomla1.0.x
    If you install for joomla!1.5.x then download ja_avian_ii_1.5_com_rsgallery2.zip HERE. The a_avian_ii_1.5_extensions.zip file include the RS Gallery component.
    @drewjackson:
    To install component by “Install from Directory” you must extracted the zip file to the new folder, ex: com_rsgallery. Next you paste the path of com_rsgallery folder into the “Install from Directory” field. Then submit Install button.
    NOTE: for joomla!1.5.x, you must Enabled System – Legacy plugin in Extensions/Plugin Manager before install RS Gallery2 component
    Hope to help for you! :)</blockquote>
    I am trying to get rsgallery2 for joomla! 1.5 template of Ja Avian II, but the link you have here says “This file is in the moderation queue “. when click Download on the right hand side it says I do not have access to it. maybe this is the same problem that jantonio is having. any idea why we cannot download it? Thanks —
This topic contains 19 replies, has 12 voices, and was last updated by  versaille123 16 years, 6 months ago.
