caninekingdom01 Friend
caninekingdom01
- February 2008
February 27, 2008 at 11:06 am #126076Hi,
Would like to make website as user friendly as possible. Please help me clean this code. Here’s the invalid markup as a result of inserting the Your Shopping Cart Module in JA Larix:
# Warning Line 67, Column 111: cannot generate system identifier for general entity “option”.
…in11/joomla/index.php?page=shop.cart&option=com_virtuemart&Itemid=26″>
etc
Thanks,
MelissaKhanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
February 27, 2008 at 4:38 pm #240426Enable sef will make your page validation.
In your administrator, select Site->Global Configuration, select SEO tab and enable SEF.
caninekingdom01 Friendcaninekingdom01
- February 2008
February 28, 2008 at 11:57 am #240595Hi,
There’s a warning: Apache only! Rename htaccess.txt to .htaccess before activating. What should I do?
Thanx
- November 2013
February 28, 2008 at 4:07 pm #240630You could see a file with name htaccess.txt on your root folder. Rename this file to .htaccess.
- February 2008
March 4, 2008 at 12:31 pm #241216The markup was valid after I followed your instructions, but when I click on any of my main links, I get this:
Not Found
The requested URL /home/canin11/public_html/joomla/index.php was not found on this server.Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.39 Server at fati.lunarmania.com Port 80Thanks for your help so far.
- February 2008
March 12, 2008 at 10:31 am #242033Hi,
I get this error when I name the file .htaccess:
Not Found
Is it because I don’t have apache setup? Would this prevent search engines from crawling my website?
Thanks,
Melissa -
This topic contains 6 replies, has 2 voices, and was last updated by caninekingdom01 16 years, 10 months ago.
