debaleena_das Friend
debaleena_das
- February 2017
March 21, 2017 at 12:44 am #1020323Hi,
I have added a slider (SmartSlider3) in the content-mass-top section. In screen sizes, where the masthead is to the left, it does not display correctly. The slider is covering the full page width and is therefore partially behind the masthead. How do I make the slider module fit in the section?A related question: is it possible to build a similar slider with JA Builder?
Thanks,
Debaleena
March 21, 2017 at 9:00 am #1020461Hi
I checked your site and the extension is not using the 100% width. Its using a fixed value of width that is why the area is not visible.
See this: http://prntscr.com/emkt19
Each container has it fixed width this why it not visible when the parent container size is less.
You can ask the extension support to make the width 100% and it will work.For the Builder Please take a look on this documentation.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Pankaj Sharma 7 years, 6 months ago.
Fix slider in content-mass-top section
