Gerard Brannigan Friend
Gerard Brannigan
June 18, 2014 at 10:19 am #198949Hi,
Our site has gone live and we have discovered a few problems with the MAsshead display.
we are losing text from the main module on some devices, it is cutting the text off after the line “paint it”.
Is there a solution to this?
thanks
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
June 18, 2014 at 3:59 pm #539387When I view your site, I am seeing the exact image you have posted above … i.e. it does not appear to be “cut off” after “Paint It” Perhaps you can post a screenshot of the “cut off” issue?
Gerard Brannigan FriendGerard Brannigan
June 18, 2014 at 5:34 pm #539390TomC ModeratorTomC
- October 2014
June 18, 2014 at 5:38 pm #539391<em>@myachill 432880 wrote:</em><blockquote>hi tom.see attached
</blockquote>Have you tested this out in other browsers – such as Firefox, Safari, IE?
June 18, 2014 at 6:25 pm #539394its a problem with mobiles and from what i can see, monitors where the resolution is 1024×786.do you think there is a solution or workaround for this?
TomC ModeratorTomC
- October 2014
June 18, 2014 at 6:27 pm #539395<em>@myachill 432885 wrote:</em><blockquote>its a problem with mobiles and from what i can see, monitors where the resolution is 1024×786.do you think there is a solution or workaround for this?</blockquote>
Hmmmm …. I’m sure there is, but I’m not certain (myself) as to the solution.
I am forwarding this on for further review/assistance to the JA Development/Support Team.
Saguaros ModeratorSaguaros
June 19, 2014 at 3:36 am #539446It looks like the font size is so bigger than expected. You can try with this workaround:
– Create a new css file called ‘custom.css‘ in this path: /templates/ja_fixel/css
– Add this css rule:
@media (max-width: 320px){
.jamasshead .jamasshead-title {
font-size: 37px;
}.jamasshead .jamasshead-description h3 {
font-size: 17px;
You can change to another value to suit your need.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Saguaros 10 years, 4 months ago.
