  • noblecode Friend
    #116854
    Hello. I am currently using the Regulus template for my site
    (just starting
    it)
    I have the Jogadgets mambot installed and would like to use the
    Gallery part
    but it does not work correctly with your template. If I change
    templates it
    works correctly.
    here is a link to my site:
    THANKS FOR HELPING…
    Hung Dinh Friend
    #209735
    Hi noblecode,
    The header animation is not Flash, it is JA moofx roller. Also, If you want to use the Jogadgets you have to load the Bot into user5, user6, user7, user8 and user9 for it to show up.
    BTW, your site look ok with my IE 6 and FF 1.5.04
    ericserrano Friend
    #210000
    How do you load the Bot (mambot) into user5, user6, user7, user8 and user9
    because I have the same problem and not finding a solution jogadgets generate the thumbnails with out problem but the lightbox efect do not work on JA_Regulus Extra
    please help
    Eric
This topic contains 3 replies, has 3 voices, and was last updated by  ericserrano 18 years, 5 months ago.
