  • nile1483 Friend
    #153354
    When i load flash banner or video in ja anion in intenet explore (all ie version), my internet explore closed with some error, when i turn off flash module its work ok
    I guess there might be something wrong in your flash code, could you post those code on here, it helps me detect the issue easier.
    For a quick fix, you can try other Joomla extension to display flash, some are available here: http://extensions.joomla.org/search?q=flash
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 3 months ago.
