  • njbarbour Friend
    #132598
    Can anybody suggest a cause of this ?
    I made a huge leap of faith and updated from 1.5.3 to 1.5.6 and pretty well got away with it. The only thing is this strange message I get on the right hand side of the page in the link below..
    Im still getting the rotating picture below but what is the error message text actually telling me ?
    http://www.corcoranrecovery.ie/mindex/index.php?option=com_content&view=article&id=11&Itemid=66
    I would really appreciate your thoughts on this..
    Cheers
    njb
    #267665
    Did you try to reinstall that module ?
    njbarbour Friend
    #268578
    <em>@nguoiabcd 76316 wrote:</em><blockquote>Hi
    Did you try to reinstall that module ?</blockquote>
    I remember we talked after the hack incident.
    I did have to uninstall and reinstall the module. Also I had to delete instances of pages using the modules and start the pages from scratch.
    I also discovered that Flashrotator does not work with sh404SEF. I had tried using this to make the site more SE friendly. Dont suppose you heard of module install patch to Flashrotator to allow it to work with sh404SEF?
    njb
This topic contains 3 replies, has 2 voices, and was last updated by  njbarbour 16 years, 4 months ago.
