  • rapid Friend
    #146052
    Hi…
    The links I’ve set on the images on Flowlist only work if I use a specific URL as listed in the configuration.php
    For example: If I have the livesite in configuration.php set to http://www.raywhitelifestyle.com (note the WWW) then the links will only work with this URL not http://raywhitelifestyle.com (no WWW)
    If I change the configuration.php livesite to http://raywhitelifestyle.com then the WWW URL won’t work the links.
    Any ideas????
    View the site HERE – you’ll have to clear your cache to test both senarios.
    Thanks.
    Anonymous Moderator
    #323897
    Hi rapid
    For the case, you should confirm with your domain manager for checking. Your website have to run fine with the www or none
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 15 years, 1 month ago.
