  • cumenda Friend
    #123468
    Hi all,
    I would like to add the Joomfish flags near the “Fonts Usertool” ( A A A).
    Joomfish is currently installed and configured but how to place the flags is a problem for me…:((
    I think I should create a module position (ex. joomfish) and that I should modify the files “index.php” and “css_template.css”.
    Can someone help me to modify those files adding the new module “joomfish” with flags showing on the left of “Font usertool” ( A A A) ?
    Thank You in advance for Your cooperation
    Michael Casha Friend
    #232059
    All you need to do is to change this:
    [PHP]<div id=”ja-usertoolswrap”>
    <div id=”ja-usertools” class=”clearfix”>
    <?php if($supported_browsers) genToolMenu($ja_tool & 3); else genToolMenu_ie6($ja_tool & 3); ?>
    </div></div>[/PHP]
    to this:
    <div id=”ja-usertools” class=”clearfix”><?php mosLoadModules(‘user6’, -1); ?><?php if($supported_browsers) genToolMenu($ja_tool & 3); else genToolMenu_ie6($ja_tool & 3); ?>
    </div></div>[/PHP]
    And place the tools into user6
This topic contains 2 replies, has 2 voices, and was last updated by  Michael Casha 17 years, 2 months ago.
