  • fasteddiejc Friend
    #136785
    I have a problem with the footer of my page. Just like in the Helio demo I want at the left the copyright information and at the right some links with seperators between them (just like Helio demo has). It does work when I put a section module at the footer position, but I want articles (Terms and use etc) instead of section links. I also tried to make a new menu, called footer menu, but this didn’t look nice. Any suggestions?
    anisjolly Friend
    #284918
    have you got a link that we could look at? preferably your site and not the helio demo link.
    it’ll make it easier for us to compare what your site looks like with the JA demo version and help us to come up with a solution for you.
    fasteddiejc Friend
    #284943
    yes ofcourse, it is http://www.dutchpreviews.com
    John Wesley Brett Moderator
    #284950
    <em>@fasteddiejc 104184 wrote:</em><blockquote> I also tried to make a new menu, called footer menu, but this didn’t look nice. Any suggestions?</blockquote>
    You are on the right track here. Helio’s right side is a menu set to the “footer” position.
    I would create the menu with article links, set it to the footer position…and then adjust the CSS to my liking.
    Perhaps you can create the menu put it in the footer position…and then let us have a look as to what needs to be adjusted.
    Have fun.
    John.
    fasteddiejc Friend
    #284951
    Thank you for your help.
    I enabled the menu I made, but it is not at the same line as the copyright line and the seperator doesn’t look like the one I see at Helio demo. I hope you can point me to the right direction 🙂
    #284966
    Set the menu’s Module position to “User 3”
    In the Module’s Parameters: make sure you have selected the correct MENU NAME…and the Menu Style should be set at “Legacy-Flat List”
    In the Module’s Advanced Parameters set the MENU CLASS SUFFIX to “-nav”
    And that should do it.
    Have fun.
    John.
    fasteddiejc Friend
    #284970
    <em>@jbrett 104256 wrote:</em><blockquote>Set the menu’s Module position to “User 3”
    Have fun.
    John.</blockquote>
    Many thanks John for your help, that did the job! Much appreciated!
    transformations Friend
    #294817
    Hi, I have the same problem and it did not work following your instructions, you can check it at http://www.etuition-italian.com The Cpoyright is slighty lower.
    Many thanks.
This topic contains 8 replies, has 4 voices, and was last updated by  transformations 15 years, 9 months ago.
