  • lbuf Friend
    #156849
    I’ve got a width problem in ja_anion. I choose rtl but then the sites get about 4000 pixels width and when I scroll out to the max, there’s a text saying:
    Powered By T3 Framework
    If this can’t be fixed, could someone then tell me how to remove the text so that the logo only remains?
    Thanks in advance
    Phill Moderator
    #364539
    Strange, I have just downloaded and installed Anion on my local testbed and do not see the problem you are having. I beleive this template was updated last week. Please try upgrading to a fresh copy and testing again. Also, it might be helpful if you post a link to your site.
    lbuf Friend
    #364557
    Tried reinstalling, but still same problem. Guess there’s a problem with the rtl footer, because that’s when the error occurs.
    Take a look here
    *edit – The problem occurs in Safari on a default Anion install. When in RTL mode a large scroll bar appears at the bottom due to the words “Powered By” being a long way to the right.
    Phill Moderator
    #364558
    What browser are you seeing this in as your page is displaying with no width problems in FF or IE8 for me.
    Phill Moderator
    #364559
    Ahh, I see it in Safari. I’ll take a look.
    lbuf Friend
    #365292
    Did you figure out something? 🙂 Still having the same problem..
    lbuf Friend
    #365293
    If not, couldn’t I just remove the text and leave the logo? I am not allowed to leave the whole footer, but leaving the text, would that be alright? If yes, how do I do that? Cause that would solve the problem..
    #365551
    Dear lbuf,
    You can try as following to remove the T3 Logo section
    Go to the file of templates/your_template/css/template.css,adding below css
    #ja-poweredby {
    display:none !important;
    I think it would help !
This topic contains 8 replies, has 3 voices, and was last updated by  Sherlock 14 years ago.
