December 2, 2008 at 9:55 pm #135880
I need the template in blue rather than the four options listed. What files do I need to modify to make this work? I’ve uploaded a new folder of images in blue to a blue folder inside images, I’ve added a blue.css to the colors folder in CSS, and I’ve added the blue.css file to the template.xml file, but I still can’t get the template screen in J1.5 to offer Blue as an option. I know I must be missing something…or maybe I’ve been staring at these files for so long I just don’t see something obvious.
Also, I have moved the four moduled footer from the bottom of the page to a spot under the slideshow where it displays quite nicely. Other than -hilite (which doesn’t seem to work on these four modules), how can I get these modules customized into the blue color scheme I need? I also have a gap between the slideshow module and the moved footer module, and I’m not sure how to remove that extra space. Any thoughts?
The site I’m working on is http://stage.ctf.org
Thanks!
Sherlock FriendSherlock
- 2478 times in 2162 posts
December 3, 2008 at 7:54 am #281083Hi mom2nine !
With footer module , you can change background for it following way below :
Please Open template.css file in templates/ja_pyrite/css folder,find following code section at about line 1099 :
#ja-botsl {
clear:both;
margin:0;
padding:0;
change to :
#ja-botsl {
clear:both;
margin:0;
padding:0;
background:blue;
December 3, 2008 at 8:11 am #281084With color additions , this is heavy customization , but :
1.please open templatesja_pyritecsscolors folder, this is folder stores css file for colors.2.Please open index.php file in templates/ja_pyrite folder , go to line 43 :
<link href="<?php echo $tmpTools->templateurl(); ?>/css/colors/<?php echo $tmpTools->getParam(JA_TOOL_COLOR); ?>.css" rel="stylesheet" type="text/css" />
this is code for switch color option
3. Please open templateDetails.xml file in templates/ja_pyrite folder, find following code section at about line 237 :
<param name="ja_color" type="list" default="default" label="Color Variation" description="Color variation to use">
<option value="default">Default</option>
<option value="red">Red</option>
<option value="green">Green</option>
<option value="orange">Orange</option>
</param>
this is code for define colors.
Hope can help you .
1 user says Thank You to Sherlock for this useful post
This topic contains 4 replies, has 3 voices, and was last updated by amoreno 15 years ago.
