  • cnglobal Friend
    #1061237
    I’m trying to figure out why my footer text is not filling up the width of the page. Hopefully you can assist and tell me why? I’m also looking for a footer with the same layout as your website – copyright, newsletter, footer menus etc. How can I achieve this?
    https://backlitdecor.com/
    • This topic was modified 7 years, 4 months ago by  cnglobal.
    Pankaj Sharma Moderator
    #1061351
    Footer is not using full width.
    if your issue related to the color kindly add this code in custom.css file
    .t3-footer .container {
        background: #000!important;
    So the footer will look same colour, Making the 100% of footer will affect the style. Let me know if you want 100% width.
    cnglobal Friend
    #1061369
    #1061374
    Add below code in custom.css file
        width: 100%!important;
    The footer copyright and module position in right side size is defined in template folder /tpls/blocks/footer.php file.
    cnglobal Friend
    #1061377
    Thanks Pankaj,
    All my text is aligned to the very right of the page now. I want it to stay within the white borders. How would I do that?
    Also my table is set to 100% but the width still isn’t reaching. Something is blocking it.
    #1061403
    By default, it uses the same width. If you will apply the code i suggested it will not look like before.
    So in case you want to show footer in the same size like white box main body, kindly remove the code i suggested.
    See this http://prntscr.com/gjoz7m
    For table issue, kindly open a new thread and add all details if issue in that post.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 4 months ago.
