April 9, 2009 at 9:36 am #140106
The footer appears on the middle of screen, how can I fix this.
Example:
jsliao Friendjsliao
- April 2008
- 236 times in 210 posts
April 9, 2009 at 9:39 am #300671looks ok to me
April 9, 2009 at 10:17 am #300676if you go the other page, you see it.
April 15, 2009 at 4:59 pm #301431I’m having the same problem. Where you able to resolve this issue?
nguyenhuu quang Friendnguyenhuu quang
- 328 times in 288 posts
April 15, 2009 at 7:59 pm #301453it is footer menu, pls open it and publish at positon: footer.
April 15, 2009 at 10:43 pm #301478That is the problem, it is published at the footer position but it jumps around the page
April 16, 2009 at 2:11 am #301502pls send live site.?
April 16, 2009 at 3:01 am #301508http://www.digivault.co.cc, I actually have a ticket open on the matter: INSTALL #JPQ-850584. I haven’t heard back though.
April 28, 2009 at 12:03 pm #302791I have the same problem. Is there anyone who knows a solution for that?
Many thanks
April 28, 2009 at 11:26 pm #302834open : template.css (line 1050)
#ja-footer {
clear:both;
color:#999999;
padding:15px 20px;
position:relative;
text-align:center;
}replace to:
#ja-footer {
clear:both;
color:#999999;
padding:15px 20px;
position:relative;
text-align:left;
}You can to edit : lef, right, center if you want, Pls try to do it
April 29, 2009 at 5:55 am #302870I have tried to edit the code. The problem is still there. http://digivault.co.cc. Can you fix this problem if I give you login information.
April 29, 2009 at 6:47 am #302873you footer is align = left
what do you want?/June 24, 2009 at 9:38 am #308930Hi, not sure if you still need advice regarding the footer…but here goes anyway (use “thank you” if it did solve your problem!)
I had the same problem. You need to edit your default.php file (templates/ja_rutile/html/mod_footer/default.php)
Now you need to add the following:
<div class=”clearfix”> your coding goes here etc…. </div>
This should now keep the footer at the bottom of the page.
It seems like this error only occurs in IE, not FF.Hope this helps!
This topic contains 14 replies, has 6 voices, and was last updated by nguyenhuu quang 15 years, 3 months ago.
