  • Pankaj Sharma Moderator
    #1058749
    You have to change the module position size from template layout options.
    Here is documentation helps you.
    imported_lorenzoadorni Friend
    #1058956
    Hello Pankaj,
    Thank you very muche for your reply. I solve by setting each module size at 100% width .
    Thank you again.
This topic contains 2 replies, has 2 voices, and was last updated by  imported_lorenzoadorni 7 years, 3 months ago.
The topic ‘Footer problem’ is closed to new replies.
