  • slate Friend
    #705304
    i?d like to embed a facebook button and the Menu items in the footer.
    First I liked to rebuild the example, like in the documentation.
    Created an “empty module” (in german…) “which allows HTML in a WYSIWYG-Editor.
    I?ve tried it like in the documentation, but it does not show the HTML.
    The editor has no filters.
    Look here: http://slate.dj-schweinfurt.de/
    I hope you can help me…
    Thanks a lot!… again 🙂 (finishing soon 😉 )
    Adam M Moderator
    #705421
    Hi @slate,
    Please navigate to admin >>> System >>> Global Configuration >>> Default Editor >>> set to None and try again.
    Adam M Moderator
    #751884
    Hi @slate,
    slate Friend
    #705498
    <em>@Adam M 497705 wrote:</em><blockquote>Hi @slate,
    Please navigate to admin >>> System >>> Global Configuration >>> Default Editor >>> set to None and try again.</blockquote>
    Thanks! Didn?t expected that it is so easy…
    Module Suffix: mod-border mod-notitle
    Where can I post the suffix?
    Maybe it does not work…
    slate Friend
    #751931
    Adam M Moderator
    #705751
    Hi @slate,
    Please navigate to admin >>> Extensions >>> Module Manager >>> edit any module >>> switch to tab Advanced and you will see the field Module Class Suffix there.
    Note: Please note that there’s 1 blank space before the class name in Module Class Suffix.
    Adam M Moderator
    #752082
    Hi @slate,
This topic contains 7 replies, has 2 voices, and was last updated by  Adam M 9 years, 2 months ago.
