fcaccount Friend
fcaccount
- July 2007
September 12, 2008 at 5:02 pm #133277Hi,
I have a problem with the footer.
Using IE7, the footer and the template tools often rise in the centre of the page and remain there until the page is refreshed.
Template ja nerine was installed with quickstart and then upgraded to joomla 1.5.7Thanks in advance
Francesco
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
September 12, 2008 at 6:05 pm #270246screenshot please
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
fcaccount Friendfcaccount
- July 2007
September 15, 2008 at 7:54 am #270577I append the screenshot you asked me.
Sometimes footer’s words are confused in the text and it is really ugly.I hope You can help me
Thanks in advance
Francesco
Sherlock FriendSherlock
- 2478 times in 2162 posts
- May 2007
September 15, 2008 at 9:55 am #270604without being able to see this on a live site, i would just be guessing.
there was a similar bug in this template, where i changed some parts of the slideshow module positions css, which solved that problem with the footer, but then again to help you out any better than just guessing we will need your live site url.+
If there is just a specific link where you have this problem, i want you to give us that exact link.1 user says Thank You to Menalto for this useful post
- July 2007
September 15, 2008 at 11:00 am #270618Dear Menalto,
I am still working on this site.
May I send You a private message?Menalto FriendMenalto
- May 2007
September 15, 2008 at 11:02 am #270619sure, go ahead.
adamwyde Friendadamwyde
- March 2008
- 5 times in 1 posts
September 18, 2008 at 10:37 am #271144I had this same problem and solved it.
Try unpublishing any modules you have in user 1, user 2 and user 5, reloading the site front end.
See if this fixes the problem and then publish your modules again.
This should work.
1 user says Thank You to adamwyde for this useful post
- July 2007
September 18, 2008 at 12:50 pm #271156Dear adamwyde,
I saw that after reloading once a page with the problem, it seems to disappear and even deleting all temporary files, caches and so on, I am not able to see it again. So I need to try on a different computer every time!
Did you had the same problem?Thank you
- March 2008
- March 2008
September 19, 2008 at 10:06 am #271338Anything published in the left module position will cause a corruption on this template.
It is a bug.
But simply, to fix the problem all you need to do is move or unpublish anything in the left module position and you will fix the problem.
Thanks all!
Adam Wydeman
http://www.anderson-gray.com1 user says Thank You to adamwyde for this useful post
- July 2007
September 20, 2008 at 6:12 am #271474Thank you very much adamwyde.
Your advice are very useful.
I’ll try to follow your instructions
Thank you again
September 23, 2008 at 7:55 am #271828Hi
Can i mark this topic is solved ?September 23, 2008 at 10:34 pm #271972Hi
I have the same problem with this template on IE6 and IE7.
I tried to fix it with the explanations found in this thread but not still fix the problem. May can you Menalto give the solution found in the css file?Sometime it appear work better but after a few time it breaks even.
This is the screeshot and the live site url but still in work.
thanks in advance
Ron
AuthorPostsThis topic contains 16 replies, has 6 voices, and was last updated by fcaccount 16 years, 3 months ago.
