laciberes Friend
laciberes
- May 2011
June 4, 2011 at 1:25 pm #164806Hi there,
I installed the JA TELINE IV template to my site, but the footer comes empty.
There’s no Copyright text which I should keep there as I’m not a licensed developer.
IAs far as I know, in the JA TELINE IV template (as it is installed with sample data) there is a footer module responsible for this content..
Any ideas about how can I get it reappear? Or kind of ‘activate’ that footer module?Thanks.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
June 4, 2011 at 5:07 pm #394688Hi,
Could you give me username+password of ftp and backend?laciberes Friendlaciberes
- May 2011
June 4, 2011 at 5:13 pm #394690Hi.Thanks for the reply, but the site is still running on localhost…
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
June 4, 2011 at 5:14 pm #394691Did you install using the Quickstart package?
- May 2011
June 4, 2011 at 5:20 pm #394692I installed the template on a pre built page, I could not install the quickstart. The footer module doesnot show up in my modulees, as it does on te test site installed with the sample data.
- May 2011
June 4, 2011 at 5:48 pm #394699So I installed the template with all sample data as well to discover how it works, and it has a footer module which is responsible for the footer as far as I see. I attach an image with the footer modul that I found in this install.
But then I installed the template (not the quickstart package) on my site that has articles, menus etc. already built on a T3 framework blank template. Now I cannot see my footer with the JA info and links, and cannot find the footer module among my modules as well.
khoand Friendkhoand
- February 2011
June 4, 2011 at 5:51 pm #394700Could you show me default layout?
- May 2011
June 4, 2011 at 5:54 pm #394702What do you mean by default layout? The layout of frontpage, with the default blank t3 template enabled? Sorry if the question is lame, I’m new to this stuff 🙂
khoand Friendkhoand
- February 2011
June 4, 2011 at 5:57 pm #394704To view default layout that you use, you login backedn > Extensions > Template manager > ja_teline_iv > Layout tab > default layout. You copy and patse it into your post. I need to view it
- May 2011
June 4, 2011 at 6:01 pm #394705<?xml version=”1.0″ encoding=”utf-8″?>
<layout name=”desktop”>
<!–Extra css load for this layout–>
<stylesheets>
</stylesheets>
<blocks name=”top” style=”xhtml”>
<block name=”absolute” type=”modules” style=”raw”>absolute</block>
<block name=”header” type=”header”></block>
<block name=”topmegamenu” type=”topmega”></block>
<block name=”mainnav” type=”mainnav”></block>
<block name=”topbar” type=”topbar”></block>
<block name=”cpanel” type=”usertools/cpanel”></block>
<block name=”slideshow” type=”modules” style=”raw”>slideshow</block>
<block name=”topsl1″ type=”spotlight” special=”left” specialwidth=”66″>sl1-l,sl1-r</block>
<block name=”topsl2″ type=”spotlight”>user1,user2,user3,user4,user5</block>
</blocks>
<blocks name=”middle” main-inner=”1″ colwidth=”17″>
<block name=”content-top” style=”raw”>content-top</block>
<block name=”content-bottom” style=”raw”>content-bot</block>
<block name=”content-mass-top” style=”raw” type=”tabs”>ja-news-1,ja-news-2,ja-news-3</block>
<block name=”content-mass-bottom”>content-mass-bot</block>
<block name=”right-mass-top”>col-mass-top</block>
<block name=”right-mass-bottom”>col-mass-bot</block>
<block name=”inset1″>left</block>
<block name=”right1″>right1</block>
<block name=”right2″>right2</block>
</blocks>
<blocks name=”bottom” style=”xhtml”>
<block name=”botsl1″ type=”spotlight”>user6,user7,user8,user9,user10</block>
<block name=”botsl2″ type=”spotlight” special=”left” specialwidth=”66″>user11,user12</block>
<block name=”footer” type=”footer” main-inner=”1″></block>
</blocks>
</layout>I hope you meant this one.
khoand Friendkhoand
- February 2011
June 4, 2011 at 6:07 pm #394706Your layout is right.
– So you try replace my attached file with templatesja_teline_ivblocksfooter.php
– Delete all of files of cache directory
- May 2011
June 4, 2011 at 6:20 pm #394709I did what you said.
Still the same problem, the footer is empty. :confused:khoand Friendkhoand
- February 2011
June 4, 2011 at 6:31 pm #394711I guess your css has problem. But I can’t find down because I can’t view it
- May 2011
June 4, 2011 at 6:36 pm #394713Is the css/template.css file the responsible one?
khoand Friendkhoand
- February 2011
June 4, 2011 at 6:41 pm #394714AuthorPostsThis topic contains 17 replies, has 3 voices, and was last updated by khoand 13 years, 4 months ago.
