February 28, 2014 at 10:07 am #195306
I need to set the background fixed, how can I solve the problem in the footer of the “Ja Mitius” template, like in the attached picture ?This is my site : http://www.arpinoturismo.it/new/
Sorry for my english
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
February 28, 2014 at 6:35 pm #524805Try This . . . .
Within file path –> /templates/ja_mitius/css/themes/red/template.css
at line 3635, make the following (highlighted) adjustments:
.ja-footer {
background: none repeat scroll 0 0 #000000
color: #666666
margin-left: auto;
margin-right: auto;
width: 1050px;
}Bear in mind, this will only work for when you have the “red” theme assigned.
To try to make the modification universal across all themes, you can also create a “custom.css” file within file path –> tempaltes/ja_mitius/css <– and place the same css rule above within that file.
Hope That Helps
March 3, 2014 at 10:42 am #525076Thanks,
I made the changes, and this is the result :
http://www.arpinoturismo.it/new/But I would like to be like that:
marco<em>@TomC 413971 wrote:</em><blockquote>Try This . . . .
.ja-footer {
color: #666666
margin-left: auto;
margin-right: auto;
width: 1050px;
Hope That Helps</blockquote>
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
March 4, 2014 at 7:13 pm #525326Hi Marco,
Please try to create a new file called “custom.css” in the /templates/ja_mitius/css path, then add the same rule suggested by TomC:
.ja-footer {
color: #666666
margin-left: auto;
margin-right: auto;
width: 1050px;
}Let me know how it goes.
March 14, 2014 at 12:28 pm #526735Almost done,
I put the original code :
[PHP]}
.ja-footer {
background: #000
color: #666
*zoom: 1;
[/PHP]
in: /templates/ja_mitius/css/themes/red/template.css at line 3635 .and I created custusm.css file in the following path: tempaltes/ja_mitius/css with this code:
[PHP]
@import url(../fonts/novecentowide1/stylesheet.css);.ja-footer {
color: #666666
margin-left: auto;
margin-right: auto;
width: 1050px;
[/PHP]That’s the result : http://www.arpinoturismo.it/new/
- April 2013
March 17, 2014 at 9:49 am #526936Please try this additional tweak. Open the /templates/your_template_name/css/custom.css file, then replace this code:
.ja-footer {
margin-right: auto;
position: absolute;
width: 1050px;
}With
.ja-footer {
margin-left: auto;
margin-right: auto;
position: relative;
width: 1050px;
}Let me know if this helps.
March 25, 2014 at 10:25 am #528033thanks it works
March 26, 2014 at 12:04 pm #528243Sorry,
I didn’t notice that this solution :[PHP].ja-footer {
margin-left: auto;
margin-right: auto;
position: relative;
width: 1050px;
}[/PHP]gives me problems with mobile Android device (default browser), like in the picture:
How can I solve that ?
- April 2013
March 27, 2014 at 7:01 am #528312@ gruppoarancione,
At present, I can not access this site.
By the way, when I try this page, I saw it’s working fine.
March 27, 2014 at 4:02 pm #528372
Sorry Nazario,
the site is now on http://www.arpinoturismo.it . I had removed custom.css“Saguaros” suggests to me this solution: (on custum.css)
http://www.joomlart.com/forums/topic/problem-with-android-default-browser/<blockquote> @media (min-width: 768px){
.ja-footer {
margin-left: auto;
margin-right: auto;
position: relative;
width: 1050px;
}</blockquote>it seems to work .
arthurjohnston Friendarthurjohnston
- November 2010
- 27 times in 2 posts
March 28, 2014 at 2:05 am #528394I have a question.
Assuming that Gruppoarancione has set the template background to “flowers” as in:
body {
background: url(“../../../templates/ja_mitius/images/flowers.jpg
}Would the following work within custom.css?
ja-footer {
background: transparent;
}Nazario A FriendNazario A
- April 2013
March 31, 2014 at 7:11 am #528719Generally, you can declare the transparent background as above via the file custom.css to overlay image background.
If you need help on this, please provide us more details how you wish to achieve and your site url. I will give better suggestion then.
1 user says Thank You to Nazario A for this useful post
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 4 voices, and was last updated by Nazario A 10 years, 9 months ago.
Footer problem with Fixed Background
