  • antoniocerasuolo Friend
    #176798
    Hi All,
    In the end I have been couseled by travel agency people to use the JA Travel template for the touring web site that i need to create. This does not meanthat they are 100% correct.. maybee there is a better template for my needs.
    In any case my web site will need to be dedicated to touring andf gathering people from outside the country mainly.
    In any case I am attaching some idea of ho the actual module should be can you please help?
    therefore:
    attachment tours desing 1: choose the date
    Attachment tours design 2: sign up for the tour
    attachment tours desing 3: personal user section of the site
    In any case I must be able to manipulate and create the forms as needed
    Please make sure that your suggestion also includes the actual add to cart and checkout web pages for the credit card payment management.
    this must be a mutli tour web site therefore with the possibility of having more than one Tour.
    Regards,
    Antonio
    1. tours_design_1
    2. tours_design_2
    3. tours_design_3
    Stork11 Friend
    #451977
    Hello antoniocerasuolo,
    I am sorry to inform that our technical support services are dedicated for bug fixing, products maintenance or general advice on how to use the products only. All custom works that requires to extend products’ core features as shown on our demo site are not subject to support coverage and should be handled by clients.
    Thus, I am sorry that we could not handle your customization request as it would delay the time for supporting other clients and developing new products for monthly release commitment.
    Thank you for your understanding.
    #451998
    I am not sure about your answer..
    I just wanted to know if there is any existing module that can be customized as needed??
    if this is not the right forum then what is the right forum??
    PLEASE HELP!!
    thank you antonio
    Arvind Chauhan Moderator
    #452007
    Hi Antonio,
    You can create forms for the above purpose but not sure if they will suffice your requirement. http://extensions.joomla.org/extensions/contacts-and-feedback/forms
    Or you can also check booking components for the same :
    http://extensions.joomla.org/extensions/vertical-markets/booking-a-reservations/booking
    At Joomlart we do not have any extension which can be adapted to your requirement, nor do we provide custom development services.
    you can even try your luck at http://www.joomlancers.com in case you want to hire someone to get the above done for you.
    Arvind
    quannv Friend
    #453146
    <em>@antoniocerasuolo 318362 wrote:</em><blockquote>Hi,
    PLEASE HELP!!
    thank you antonio</blockquote>
    Hi antoniocerasuolo,
    If you buy Ja travel already, you can go to http://joombooking.com to find component can install in that template
This topic contains 5 replies, has 4 voices, and was last updated by  quannv 12 years, 6 months ago.
