  • marielathey Friend
    #143176
    Every time I post an article to the front page- there is a number one associated with it. Please help me get rid of this. I looked at it with firebug, but cannot seem to figure it out.
    Thanks!
    http://www.incacrossings.com
    hanifahmed Friend
    #312924
    Take a look at your template html in template editor and see if there is a “1” hanging about by itself in there. You probably just pressed it by accident and didn’t realise it.
    marielathey Friend
    #312929
    Thanks for your reply… but I am not sure about exactley which file you are referring to. Could you be more clear. I have been opening files and looking for random “1”‘s but that is like trying to find a needle in a haystack.
    marielathey Friend
    #313014
    Hello
    Can anyone help with this??:confused:
    marielathey Friend
    #313165
    Hi!!
    I have requested help and no one from Joomlart seems to respond- PLEASE help!!
    hanifahmed Friend
    #313347
    Try submitting a support ticket – they’ll respond as soon as they can and should be able to solve the problem for you – seeing as no one appears to know!
    Hello marielathey!
    Which the module you have used for display articles ?
    May be it’s a result when developer debug, I don’t know you haved modify anything with this extension?
    Please try to find and open in php file which process logic and get those articles, You looking for some code debug or number 1, are they appear in there?.
    if it’s very difficult to do, or you could not found, please submit a ticket to the Joomlart Support Department, JA will check and resolve your problem.
This topic contains 7 replies, has 3 voices, and was last updated by  Saguaros 15 years, 4 months ago.
