  • marginmedia Friend
    #143666
    I have recently stumbled across a problem. My front page articles which yesterday were visible are today not visible. I have tried creating new articles and posting them to the frontpage, however this does not work.
    The problem did arise when I called my host to change my open_basedir path. I then called my host to change this path back to the original.
    All the pages on my website display as they should. All modules on my home page are visible. It is only the frontpage articles that are not visible.
    Has anyone stumbled across this problem and can anyone help me with it.
    Thanks in Advance
    M
    itsnexgen Friend
    #327356
    I got such problem.
    Try to check all the frontpage articles whether they fit the proper html code. Did u try to copy paste teh contents directly into editor?
    Daniel Michaels Friend
    #327905
    I’m having the same problem with JA Quartz. Front page articles are suddenly gone! I had this problem long ago on a different Joomlart template (never on other templates) and had to switch to a different template provider. I’m back and surprisingly just as frustrated. This, combined with the LONG wait for responses on this forum, will likely lead me away again.
    Please advise.
    I double check html code…every front page article is clean.
    I also compared the index with a different demo installation that works and they are both exactly the same. Permissions are correct. .htaccess is routing properly. And, most strange…it worked a few weeks ago.
    #327907
    OK, to my total surprise, I actually found the problem.
    I’m not sure why, but one of my sections was mysteriously unpublished. This section included several of my front page articles. When I published the section, everything works again.
This topic contains 4 replies, has 3 voices, and was last updated by  Daniel Michaels 14 years, 11 months ago.
