  • paulhandyman Friend
    #186176
    I have problem with setting 2 columns article layout on JA ELASTICA frontpage (blog layout)… Going to: backend>Menus>Mainmenu>Home and setting layout to 2, 3 or 4 columns doesn’t have any impact on the front end. Eventually I solved this problem by deleting in temtemplates/ja_elastica/css/layout-wide.css
    .cols-1 .item, .cols-2 .item, .cols-3 .item, .cols-4 .item, .cols-5 .item {
    width: 100% !important;
    and changing templates/ja_elastica/css/layout.css
    .cols-2 .item {
    width: 50%;
    to
    .cols-2 .item {
    width: 50% !important;
    float:left;
    Now there are gaps between articles in main content area (see attached picture)
    how to eliminate the gaps between the articles ??? I spent a couple of hours tweaking the CSS with Firebug but no luck so far….
    Can anyone help please… Thank you in advance !!!
    1. screenshot
    phong nam Friend
    #487988
    Hi paulhandyman,
    In general, the default layout of Article Featured – Joomla Content component is that It will sort your 2 columns into one row, which is counted from row-0 –> row-3 (4 rows with 8 articles on your homepage). The reason for the gaps is the different size of images in 2 articles of same row. You can see my snapshot for details.
    I regret I couldn’t correct style for this issue. But you can see the codes which defined sorting 2 article in one row in
    <blockquote>templatesja_elasticahtmlcom_contentfeatureddefault.php</blockquote>.
    [PHP]
    <?php
    $key= ($key-$leadingcount)+1;
    $rowcount=( ((int)$key-1) % (int) $this->columns) +1;
    $row = $counter / $this->columns ;
    if ($rowcount==1) : ?>
    <div class=”items-row cols-<?php echo (int) $this->columns;?> <?php echo ‘row-‘.$row ; ?>”>
    <?php endif; ?>
    <div class=”item column-<?php echo $rowcount;?><?php echo $item->state == 0 ? ‘ system-unpublished”‘ : null; ?>”>
    <?php
    $this->item = &$item;
    echo $this->loadTemplate(‘item’);
    </div>
    <?php $counter++; ?>
    <?php if (($rowcount == $this->columns) or ($counter ==$introcount)): ?>
    <span class=”row-separator”></span>
    </div>
    <?php endif; ?>
    [/PHP]
    1. 3-28-2013-5-15-29-PM
This topic contains 2 replies, has 2 voices, and was last updated by  phong nam 11 years, 9 months ago.
