  • imsleepy Friend
    #137580
    I have a problem with my front page. I have installed the JA News FP thingy. I set the Front Page to display 0 news items because I wanted them all to show in the JA thing instead of the regular blog display. That worked, but you will also notice that a piece of the graphic for the bottom of the main content is still displaying where the blog would have been (You can see it below the JA News thing).
    How do I make that go away short of deleting it from the images? If I do that, the bottom would be missing from all main content items.
    Thanks for any help you can give.
    bennitos Friend
    #288537
    this may be a bit of a “dirty” fix but it works:
    template.css file line 601
    #ja-current-content {template.css (line 601)
    margin:0;
    padding:20px;
    remove the item marked in red
    imsleepy Friend
    #288540
    Well, tried it and yes it did work, but no it didn’t. I see why it’s a “dirty fix”. It took care of the problem with the graphic still showing on the front page, but then all of the text on inner pages was out of alignment. So, had to change it back.
    Any other suggestions?
    Thanks for trying…. it was worth a shot.
    jwellman Friend
    #288549
    Not sure if I can help but I used this template and was having issues with some of the graphics “breaking out” as well.
    Did you read this topic? They may have changed the error in the new downloads but it may help with some of your issues.
    http://www.joomlart.com/forums/topic/main-content-text-break-out-of-design/
This topic contains 4 replies, has 3 voices, and was last updated by  jwellman 15 years, 11 months ago.
