  • ukfraternite Friend
    #137512
    I am experiencing some layout problems, AGAIN.
    I have not added any article to the site recently and the LEFT and RIGHT Modules have just shifted to the bottom of the page.
    Could anyone help me on this, please? I must say that this happens ONLY with Internet Explorer. Firefox is OK.
    Thank you.
    rhand Friend
    #288275
    Internet Explorer 7 seems to display it just fine. At least like Firefox 3.0.5. I guess it’s a IE6 box problem. Just try to make the witdh or padding of both modules a little less in template.css. Unless there is an IE6 specific file for JA Telline.
    Another option you could try is changing the doc typt to:
    <!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.01 Transitional//EN” “http://www.w3.org/TR/html4/loose.dtd”>
    mj1256 Friend
    #288280
    this can also be caused by poor coding in your content articles. Look for tags thatwere not closed, usially a <div> or a <P>. Joomla 1.5.x is very sensitive to this
    ukfraternite Friend
    #288283
    Problem solved. It was related to width lenght.
    I resized them some modules and it worked.
    Thank you both.
This topic contains 4 replies, has 3 voices, and was last updated by  ukfraternite 15 years, 10 months ago.
