  • geeko80 Friend
    #167507
    two questions from a newbie:
    1 – where can i find the setting for the front page/main body?
    2- If i click on Articles in the front page or in the contentslide they are visualized in the home page without left and right modules.
    Is it possible to visualize the article in their normal path? gategory-section.
    I hope you can understand what i mean.
    thank you
    Trimud Friend
    #406661
    1 – setting are in Menus – Main Menu – Home
    2 – You have to create menu which points to the category or section this article belong.
    geeko80 Friend
    #406684
    <em>@Trimud 260287 wrote:</em><blockquote>Hi,
    Regards</blockquote>
    1- ok thank you, i found it
    2- i’ve already created the menu, all my categories and articles are under the top menu (disabled) but if i try to open the article showed in the front page it will be open in home. on the other hand articles showed as links and not as leading or intro in the front page works as expected. Ay idea?
This topic contains 3 replies, has 2 voices, and was last updated by  geeko80 13 years, 3 months ago.
