  • Walter Doljar Friend
    #157518
    1. When I have articles on the frontpage – the module which should be on the right position moves down.
    link: http://5t3qs.w4yserver.at/index.php
    2. There is no distance between the frontpage-articles.
    Any ideas?
    …same Problems on Category-blog-layout! (see menue: news/presse)
    aman204 Friend
    #367141
    1) Check in your articles for mismatch of div tags or closing </div> tags if they tend to be missing (The article html code can be checked easily with editor turned off)
    2) Can you please be more specific
    #367146
    I have removed the div tags / now i do not use the JCE with div-tags any more:
    the problems with the module-position disappeared.
    thank you!
    second problem:
    how can i change the “space” between the articles on frontpage – i´m using two colums on frontpage, but there is only a little distance between the 2 columns. i need more space.
    aman204 Friend
    #367185
    2) You can change this::
    .cols2 .article_column {layout.css (line 189)
    width:50%;
    to
    margin:0 31px 0 0;
    width:45%;
    Mainly, You can adjust both width and margin value in correspondence with each other
This topic contains 4 replies, has 2 voices, and was last updated by  aman204 14 years ago.
