  • Christian Friend
    #131922
    http://www.liberiawebs.com
    I don’t know what is happening here.
    My video, hot topic, and other modules have shifted to the bottom instead of being on the right.
    Bruce
    zdiar Friend
    #264343
    First, I suggest that you should unpublish the ja-frontpage-news modul.
    If your site looks normal then the problem lies in this modul.
    The third picture in FP-news seems to be too wide a little bit.
    But maybe the problem lies somewhere else.
    bossep Friend
    #264378
    Hello zdiar,
    I was running your page in the w3c validator:
    http://validator.w3.org/check?uri=http%3A%2F%2Fwww.liberiawebs.com%2F&charset=%28detect+automatically%29&doctype=Inline&group=0
    It seems that you have a lot of markup tags in your articles. The front page dosent like that. Specially div and span. I also noticed that you are doing paste from word or somthing else microcrap. That doesent make joomla happy!
    The problem you have is most likely to be an open div tag. I had the same problem and had to go trough all articles and clean it up.
    I do think that my fix for removing tags could help but you might still be stock with bad html in other places like category view, etc. http://www.joomlart.com/forums/topic/bug-swedish-characters-not-displayed-correctly-in-ja_news/
    Please let me know how it works.
    Bosse
    zdiar Friend
    #264381
    <em>@bossep 72275 wrote:</em><blockquote>Hello zdiar,
    http://validator.w3.org/check?uri=http%3A%2F%2Fwww.liberiawebs.com%2F&charset=%28detect+automatically%29&doctype=Inline&group=0</blockquote>
    Thanks, but it is not my page, but wcb02’s.:)
    bossep Friend
    #264385
    Sorry my frined!
    My above post was for wcb02. 😮
This topic contains 5 replies, has 3 voices, and was last updated by  bossep 16 years, 3 months ago.
