  • suerly Friend
    #154449
    Hi i have installed social on an existing site, but the thumbnail images on the homepage aren’t resizing. Is it possible to resizse the pictures on the frontpage for “older” articles or does this only work for new articles?
    Thanks for your help
    Please kindly configure for the thumbnail plugin similar as my snapshot! and the image is not linked image which from other site, the resizing image only work with image putting in the same directory with the website project
    suerly Friend
    #356277
    Thank you for your response – unfortunately this is still not working – the images are stored in the usual stories directory – should I be storing them somewhere else?
    aman204 Friend
    #356278
    Please ensure that you have added values in accordance with articles set for parameters of specific menu item
    Like, You wish to have #leading images to be affected, Enter in some value in leading images and vice-versa
    Also, Please clear your browser cache after making changes
    <blockquote>the images are stored in the usual stories directory – should I be storing them somewhere else? </blockquote>
    It is default image directory set in joomla so it should be fine. Also, You can check if you have set images folder set to chmod 777
    suerly Friend
    #356285
    Hi – I have checked all the settings, cleared the cache and chmod to 777. Still not working, have included an image of my settings just in case I’m doing something wrong.
    1. thumbnailplugin
    suerly Friend
    #356287
    Screengrab of my homepage with non working thumbnail
    1. thumbnailprbolem
    aman204 Friend
    #356329
    Will it be possible for you to please pm me superadmin details to take closer look
    allexiel Friend
    #356570
    I had the same problem 🙂
    I did found a solution for my template : You’ll have to edit the settings of your Frontpage (Menu Item – Frontpage link)
    Be sure you have no Main article, but only “intros”. If you have a leading article, the plugin doesn’t work.
    # Main 0
    # Intro 3
    # Columns 1
    # links 0
    Urszula Dziki Friend
    #356599
    Yes I had same problem couple of days ago and allexiel is right it should solve your problem with images I used settings Leading 0 too Main point is to not use leading article.
    russh Friend
    #357671
    I just followed your advice and it’s correct – but surely if the leading article needs to be disabled then the plugin isn’t working as designed. It’s supposed to resize leading article images on the Front page as-well!
    micheltorres Friend
    #362550
    I´m trying many possibilities and there is no way to JA thumbnail works like expected.
    If I change HOME menu settings to
    # Main 0
    # Intro 3
    # Columns 1
    # links 0
    images and plugins to facebook and twiiter doesn’t work. Only show if I change menu settings to
    # Main 2
    # Intro 0
    # Columns 1
    # links 0
    But images isn’t be resized.
    Please HELP ME!
    russh Friend
    #362916
    <em>@micheltorres 203152 wrote:</em><blockquote>I´m trying many possibilities and there is no way to JA thumbnail works like expected.
    # Main 0
    # Intro 3
    # Columns 1
    # links 0
    # Main 2
    # Intro 0
    # Columns 1
    # links 0
    Please HELP ME!</blockquote>
    Have you checked the permissions on your resized images folders? I’d expect your apache owner to be able to read/write to them?
    micheltorres Friend
    #362933
    Hi russh,
    The folder permissions is already 777. Cache cleaned.
    Any other idea?
This topic contains 13 replies, has 7 voices, and was last updated by  micheltorres 14 years, 1 month ago.
