  • frame4 Friend
    #118155
    There is a gap between the pathway and the main body in IE.
    Shows OK in FF. Any ideas how to remedy this?
    (See attachments)
    Regards,
    Anthony
    PS : Is it because I have removed the text that gets shown in the pathway??
    1. IE
    2. FF
    Khanh Le Moderator
    #212918
    Hi Anthony,
    Do you see the gap in our demo site? If not in the demo, please post your live site here.
    frame4 Friend
    #212922
    <em>@khanh 5785 wrote:</em><blockquote>Hi Anthony,
    Do you see the gap in our demo site? If not in the demo, please post your live site here.</blockquote>
    http://www.frame4.com
    As far as I can see, this happens only if there are no left and right modules active.
    Anthony
    frame4 Friend
    #212936
    I added a section just above mosmanibbody to show the banner, commented the code (for future use) BUT …. it has solved this issue? How come??
    Anthony
    Khanh Le Moderator
    #212961
    What code do you add to show the banner?
    frame4 Friend
    #212971
    <em>@khanh 5846 wrote:</em><blockquote>What code do you add to show the banner?</blockquote>
    I have added the following code:
    <!-- ADDS BANNER
    <?php if( mosCountModules('banner') ) { ?>
    <?php echo mosLoadModules('banner'); ?>
    <?php } ?>
    Why it works, I don’t know.
    Regards,
    Anthony
This topic contains 6 replies, has 2 voices, and was last updated by  frame4 18 years ago.
