  • caclemor Friend
    #131665
    This is a very elementary question but I keep facing the same issue over and over again.
    When I try to add content to an article, the content that I type keeps extending across forever unless I place a hard return. I find myself constantly typing content, saving, then going to the live site to see if the alignment of the text is correct.
    So then I try to place content in tables, fix the column and row width but it still does not hold it to a specific width. I have set tables to 450 px widths and it still just extends and extends and extends.
    I know there has to be a simple solution and I am just missing it. I really feel like a nimrod because I can’t figure this out. I had a similar issue when I used a Rocket Theme template.
    I am thinking I should be able to just type in the content pane and the width of the content pane for the template will adjust. Or, set a table and the content will fit inside the table based on the width of the table.
    Adivce Joomla users?:)
    mj1256 Friend
    #263503
    have you installed the JCE editor Component and its mambots
    caclemor Friend
    #263542
    i did the standard install. is there something else I should have done? Thanks for the reply
    caclemor Friend
    #263562
    thanks I found it and it seems to be working great. thanks for the reply!
This topic contains 4 replies, has 2 voices, and was last updated by  caclemor 16 years, 4 months ago.
