  • wredny Friend
    #162994
    I noticed that the JA Teline services, run very slowly. Not just my site, but other services as well. I checked a few sites based on JA Telone (version 3 and 4) – all run very slowly. Is there any way that site has loaded faster?
    So why does it work?
    ok, please go to administrator => template configuration then disable the Development , enable the Cache Option,
    Then check this issue again
    jedileong Friend
    #387750
    Dear tienhc, i have the same issue, my site sometime will hang on half way or keep loading – without cache.
    But if i enable cache in global configuration, the layout will run away. any idea for this issue?
    Sorry for my english
    ok, if you got the link , please provide me , now you try to enable the Optimize css, optimize js, and disable the development mode, enable cache then let me check
    jedileong Friend
    #389811
    hi tienhc,
    thank you for your reply.
    I reinstall the whole thing, and it’s fine now. – thanks
This topic contains 5 replies, has 3 voices, and was last updated by  jedileong 13 years, 7 months ago.
