  • Samir Mastaliyev Friend
    #188233
    hi. my cpanel error log continuesly gives following errors. How can i turn off that fonts or may be fix this problem?
    [Fri Jun 14 00:05:22 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:05:15 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:05:06 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:05:05 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:04:51 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:04:45 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:04:18 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:04:17 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:03:59 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:03:44 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:03:38 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    [Fri Jun 14 00:03:06 2013] File does not exist: /home/banker/public_html/aze/undefined, referer: http://banker.az/aze/
    Hi mastaliyev,
    Could you specify font file that does not exist as noticed in above log?
    #496035
    i can’t . but my hosting said that this error mean so.
    It’s hard to locate which file/ which font causes this issue with that info, did you face this issue with default Joomla template? you can try to switch default template to another standard Joomla template to check it.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 5 months ago.
