  • elaine millward Friend
    #142852
    On the right hand side of the template when I put a new module in this automatically appears in a grey box. Any ideas how to remove the grey box on some modules and not on others? Cheers. 😀
    bennitos Friend
    #311567
    can you post a picture, or even better a live url (can do in pm if prefered) will be a lot more simpler to help you that way.
This topic contains 2 replies, has 2 voices, and was last updated by  bennitos 15 years, 5 months ago.
