This topic contains 840 replies, has 816 voices, and was last updated by alexandru292 9 years, 1 month ago.
ok yaaaaaaaaaaaaa
thanx
Girish
Yohann
Only moderators can see that information, i would suggest you create a temporary account wich you provide and disable or delete it later if your issue is solved.
happy to be a ja member
i attempted to change the template JA Sulfur logo to my own label by saving my company’s logo file as logo.png over the original JA Sulfur template logo in the ../template/jasulfur/jasulfur/ folder. While the original JA Sulfur template logo is no longer there, the logo I inserted is not visible either.
Please tell me what I’m doing wrong. Thanks.
Btw, the site URL is http://www.letitv.com/dancelife
Thank you.
Thanks for the info
reodon59
Thank you for this forum, great information here.
Thanks for the help
thank you very much for the information..
Thanks, very helpfull
Thank you very much
I always emphasized on security issue. And also feeling happy to be a JA Member. 🙂
Excellent Template…keep up the good work!
