October 25, 2017 at 12:13 pm #1070013
I have problem in final step of installation JA Simli quickpack process it’s stopped when the screen has faded away and frozen there, is there some pro help me?
October 26, 2017 at 1:23 am #1070105Hi
It can be due to your localhost PHP values
Increase the Max execution time and memory limits from php.ini and perform the installation again.Regards
October 29, 2017 at 11:26 am #1070705Same problem. In htaccess prescribed php_value max_execution_time 1800 php_flag magic_quotes_gpc Off php_value memory_limit 150M php_value upload_max_filesize 25M php_value post_max_size 25M Not helping! With respect!
October 30, 2017 at 2:57 am #1070813Hi
Kindly set the max execution time 300 and memory limits 512M, On localhost, i am not sure that the values are working or not, if possible kindly put the site live so i will have a look on itRegards
November 4, 2017 at 8:06 pm #1072357Hi
I had the same problem with the quickstart on a local installation (Windows 10 and Xampp), but your tips solved the problem.
Thanks!Pankaj Sharma ModeratorPankaj Sharma
November 6, 2017 at 3:12 am #1072511<div class="d4p-bbt-quote-title">Pankaj Sharma wrote:
Thanks!You are welcome!
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 4 voices, and was last updated by Pankaj Sharma 7 years ago.
Have problem with installation in the third step with JA SIMPLI quickpack
