ezaban Friend
ezaban
- August 2013
June 28, 2015 at 7:56 am #207966Hello Everybody,
It appears that the Ja teline I have installed on http://www.ezaban.com is not complete because I have also installed this template on another domain http://www.iranbon.net and it works perfectly. (I installed it via quickstart)
In my main website http://www.ezaban.com the layouts are not installed and even I can not see the module positions in the layout part of template manager > Ja Teline > Layouts (but I can see it is working very good on the version I have installed via quickstart)When I installed Ja Teline using quick start on my other domain (http://www.iranbon.net) , On templates I see all layouts like magazine, gallery, events and … So I have four or five Ja Teline in Template Manager
But in the main website there is just one Ja- Teline Default template.
Another problem, when I go to layout on quick start one, I can easily see the layout of each theme. I can see the boxes and positions and etc.
But in the main site that I have installed ja teline , I cannot see the layouts. I just see the names. No template position ….
Also Preview in thememagic does not work in the installed ja teline in the main site but it works very good on the quick start one. And I can see that each menu has its own css color.
Can you guys check it yourself via admin information I have provided when posting this thread?
Thank you,
pavit Moderatorpavit
June 28, 2015 at 8:09 am #575711Hi
Your template on http://www.ezaban.com works fine
If you install quickstart version you have all positions and templates layout already configured for pages
If you install the template file indeed you need to recreate them again if you want new layouts to be available
so you need to create a new layout for each page choosing from the layouts available from drop down
for example if you want to create the gallery page then you have to create a neW template Ja-TELINEV – GALLERY and assign to it the Gallery layout as showed here
I taked this screenshot from your website so all the layouts are correctly available as you can see
You can copy templates settings from the quickstart version and reproduce them on your website
Please take also a look at the documentation page HERE
June 28, 2015 at 8:09 am #642040Hi
June 28, 2015 at 8:09 am #740700Hi
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by pavit 9 years, 6 months ago.
Have problem with layouts and other
