  • swedeboy Friend
    #157393
    I just installed this theme, everything went well except my logo isn’t working.
    I have uploaded my logo to templates/ja_teline_iv/images and replaced the original logo, but for me the logo is not showing up.
    The other issue I have is the logo at the bottom.
    Would really appreciate if someone can take a look and help me solve this.
    Link to my site: http://www.queermagazineonline.com
    Thanks,
    Anders
    aman204 Friend
    #366679
    Change this::
    h1.logo a {color.css (line 22)
    background-image:url(“../images/logo.png”);
    to
    /*h1.logo a {color.css (line 22)
    swedeboy Friend
    #366685
    Thank you so much for your reply and help.
    That solved the problem 🙂
    Anders
    thuanlq Friend
    #366686
    your problems are because you choose color template ( currently it is “read-color”), so your logo image upload to incorrect path,
    correct path is templates/ja_teline_iv/core/themes/red-color/images/. If you don’t want upload to this path, and use path templates/ja_teline_iv/images. Edit file template.css at path “templates/ja_teline_iv/css/”, change code
    h1.logo a {
    background:url(../images/logo.png);
    display:block;
    height:85px;
    width:341px;
    to
    h1.logo a {
    background:url(../images/logo.png) !important;
    display:block;
    height:85px;
    width:341px;
    Or please remove code in file color.css at path templates/ja_teline_iv/core/themes/red-color/css/
    background-image:url("../images/logo.png");
    ithacaindy Friend
    #367499
    I want all color profiles to use the same logo – how do I specify that?
    Phill Moderator
    #367503
    You would need to edit the css in each colour profile to point to your logo. Bit of a faff I know but should not take long.
    ithacaindy Friend
    #367505
    I found a much easier method. Simple append “!important” to the logo statement in template.css
    Phill Moderator
    #367508
    I didn’t think of that, well done.
This topic contains 8 replies, has 5 voices, and was last updated by  Phill 14 years ago.
