  • TomC Moderator
    #120634
    I’m having a problem getting the TransMenu to work properly within my Xenia II site.
    What position is the TransMenu supposed to be in?
    I ask because I cannot get the submenu dropdown feature to work, so I’m thinking I may have my TransMenu assigned to the wrong position. I have unpublished the Main Menu module – as instructed in the tutorial, but it just doesn’t seem to be working.
    One thing …. I was playing around with trying to get TransMenu to work with a different template and I created a new position for it within that template. When I switched back to Xenia !! as the default, the TransMenu held to that position – even though it doesn’t exist in Xenia II. So, I cannot figure out how to get the menu to work properly – with the submenu items in dropdown (as they are supposed to).
    Any thoughts/suggestions?
    TOM
    TomC Moderator
    #221453
    Great Googly-Moogly . . . . Nevermind.
    The answer was right there in the user guide . . . .
    To choose your menu type, go to the 32rd line in the “ja_xenia/ index.php” and change $ja_menutype to what you need.
    1 is Split Menu, 2 is CSS Menu, 3 is Transmenu and 4 is Script Dropline Menu
    Well, if anyone else has this same issue, hopefully my “shoot from the hip” question and solution will help.
This topic contains 2 replies, has 1 voice, and was last updated by  TomC 17 years, 6 months ago.
