August 22, 2007 at 9:52 am #122235
hi,
sorry my english is very bad.
i have a problem with navigator in the header on
creative-suite.de/ksm2007
the navigator scroll to the right and not down and the right….
my header index.php
<!– BEGIN: HEADER –>
<div id=”ja-headerwrap”>
<div id=”ja-header” class=”clearfix”><h1>
<a href=”index.php”>
<?php echo $mosConfig_sitename?>
</a>
</h1><div id=”ja-mainnav”>
<?php
switch ($ja_menutype) {
case 1:
//echo $topnav;
$jasplmenu->genMenu (0);
break;
case 2:
echo “<div class=”sfmenu-inner”>”;
include($ja_template_absolute_path.”/ja_cssmenu.php”);
echo “</div>”;
break;
case 3:
echo “<div class=”transmenu-inner”>”;
include($ja_template_absolute_path.”/ja_transmenu.php”);
echo “</div>”;
break;
case 4:
echo $topnav;
break;
</div></div>
</div>
<!– END: HEADER –>Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
August 22, 2007 at 10:08 am #227813Installed with the quick start package??????Have you done any changes in the template??
August 22, 2007 at 10:19 am #227814Installed with the quick start package??????Have you done any changes in the template??
Yes i installed the quick start package…
i have some change, but it works, when i put the navi under the header….
- May 2007
August 22, 2007 at 12:07 pm #227831<em>@entiac 25391 wrote:</em><blockquote>Installed with the quick start package??????Have you done any changes in the template??
i have some change, but it works, when i put the navi under the header….</blockquote>
Try to revert it back to original,all files
August 22, 2007 at 12:47 pm #227835it works not really
http://www.creative-suite.de/ksm/
when i cut the second navi it is the resembles problem
This topic contains 7 replies, has 2 voices, and was last updated by entiac 17 years, 3 months ago.
