  • christoscologne Friend
    #1006537
    when I open my site http://www.luxuszelt24.de on a mobile device then the head fonts look broken.
    But when I reload the site, than it looks normally again.
    I tested it on a Samsung Galaxy A3.
    Please take a look at the screenshot for further understanding.
    I need some help.
    Thanks an best regards,
    Chris
    1. Screenshot_20170129-131522
    Pankaj Sharma Moderator
    #1006554
    Add below code in /css/custom.css file in template folder and add below code
        @media (max-width:768px){.blog-featured h1 {font-size:20px;}}
    Change the font-size as per needs .
    #1006562
    I have changed it but have still the same issue. I changed the font-size to 12px, but the issue still remains.
    By the way the issue appears also with h2.
    Please see screenshot.
    Regards,
    Christos
    1. Screenshot_20170129-153641
    #1006564
    Use the same code for h2. Replace H1 with h2.
    #1006566
    ok thanks, but I just wrote you that the issue still remains. Nevertheless it is H1 or H2?
    The problem was not solved with your suggestion.
    #1006569
    Can u tell me what problem is not solved?
    H1 and h2 tag use default font size , so its not an issue. But you use above code to override the style code.
    #1006570
    please take a look at my latest screenshot. The headline is broken though I made the changes you suggested.
    #1006571
    Can u test it on other device, i am nit able to replicate the problem.its normal like on demo.
    1. Screenshot_2017-01-29-21-09-28-407_com.android.chrome
    #1006573
    why is the headline so big in your screenshot? I changed it to 12px for testing your code.
    Can you please close the site and open it again. NOT just reload. Then you sure will see what I see.
    #1006630
    The code is working fine and there is no issue in Title display: http://prntscr.com/e21jvw
This topic contains 9 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 11 months ago.
