jcnr Friend
jcnr
- September 2010
December 31, 2013 at 1:05 am #193365Hi there, i have 2 details i would like to get some help with if possible:
1º – Is it possible to make the upper modules (HEADER and MENU) absolute, i mean with the site scrooll down or up those modules would stay in the same position without moving.
2º – I published some modules in positions user21, user22, user23 and user24 and the links hoover and without hoover are weird for the template i have tried for lquite some time to change it in CSS but i cant find where it is, i wanna change that grey to bleu and on hoover white.
Thanks in advance for all the time given to these issues
JCNR
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
December 31, 2013 at 7:53 am #516992Hi JCNR,
<blockquote>1º – Is it possible to make the upper modules (HEADER and MENU) absolute, i mean with the site scrooll down or up those modules would stay in the same position without moving.</blockquote>
Is there any sample link showing how they should be? Do you mean the menu will be sticky like in our recent template?
<blockquote>2º – I published some modules in positions user21, user22, user23 and user24 and the links hoover and without hoover are weird for the template i have tried for lquite some time to change it in CSS but i cant find where it is, i wanna change that grey to bleu and on hoover white.</blockquote>
Please set “NO” for “Enable Development Mode” and “Optimize CSS” in template manager. Then send me the URL of your site so that I can help you out.
jcnr Friendjcnr
- September 2010
December 31, 2013 at 4:43 pm #517012<em>@Nazario A 404003 wrote:</em><blockquote>Hi JCNR,
Please set “NO” for “Enable Development Mode” and “Optimize CSS” in template manager. Then send me the URL of your site so that I can help you out.</blockquote>
Hi, tks for the quick reply
1º Yes, exactly i would like logo and menu to be sticky that they dont move at all if i scrool down the page
2º The setting you asled for are placed and the url is http://www.colegioddinis.pt/cdd
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
December 31, 2013 at 6:19 pm #517023Try This . . . .
For the Header/Logo section . . .
Within file path –> /templates/ja_university/css/template.css
at line 931, modify as follows:
#ja-header {
background: none repeat scroll 0 0 #10151C
border-bottom: 1px solid #000000
position: fixed;
}Then, for the main nav . . .
at line 1019, modify as follows:
#ja-mainnav {
border-top: 1px solid #1B212A
font-size: 0.923em;
position: fixed;
top: 75px;
z-index: 20;
}Last, for the “main/topsl1” section . . . .
at line 1143, modify as follows:
#ja-topsl1 .main {
border-bottom: 1px solid #EFECE1
margin-top: 120px;
padding: 30px 0;
}SAVE CHANGES — CLEAR CACHE — REFRESH PAGE
Does that achieve the result you were going for?
jcnr Friendjcnr
- September 2010
January 1, 2014 at 3:15 pm #517051Hello TomC
thanks in a million, it is nearly there, it works at some point, but in the main page it conflits with the ja slide show lite, and also in mobile view the header stays under the menu. And if i use any link to any article the header and menu is no longer sticky.
Please check it out in http://www.colegioddinis.pt/cdd.
Also is its not too much trouble, in position user21 i got published and the css is not quitte the blue theme it appears grey on normal link and dark blue on hoover. Where to change those color…
thanks again for all the help. cheers
- April 2013
January 2, 2014 at 1:53 am #517075Hi jcnr,
Please try workaround below:
– Open file: …/templates/ja_university/css/template.css
– Modify CSS declaration as follows:#ja-slideshow {
background-attachment: scroll;
background-clip: border-box;
background-color: #D7E3E3
background-image: none;
background-origin: padding-box;
background-position: 0 0;
background-repeat: repeat;
background-size: auto auto;
border-bottom-color: #C3D5D5
border-bottom-style: solid;
border-bottom-width: 1px;
margin-top: 121px;
position: relative;
z-index: 9;
}Remember to clear JAT3 cache. Let me know how it goes.
1 user says Thank You to Nazario A for this useful post
jcnr Friendjcnr
- September 2010
January 2, 2014 at 4:59 am #517101Hello thanks once again Nazario i choosed now to sticky only the header
All is ok as i wanted in home page, but i got now a more weird problem i figure out why the modules placed under the #ja-botsl2 tag appeard grey and dark blue and i added to the blue theme css the following code to obtain the result i want
#ja-botsl2 a {
background-image: url(../images/bullet-dark.gif);
color: #6991b7
}#ja-botsl2 ul.menu li a {
color: #6991b7
}#ja-botsl2 a:hover,
#ja-botsl2 a:focus,
#ja-botsl2 a:active {
color: #fff
}#ja-botsl2 ul.menu li a:hover,
#ja-botsl2 ul.menu li a:focus,
#ja-botsl2 ul.menu li a:active {
color: #fffBut when ever i link a category in blog view this changes and that css is not absorved as also the sticky header stops being sticked, it appears like when in blog view there is another css file is taking place, please check the following link to view what i mean http://www.colegioddinis.pt/cdd/oferta-curricular the same happends for example in http://www.colegioddinis.pt/cdd/oferta-curricular but if u go to home page or any page the represents a single article the module published under that tag in user21 position appears as i wish.
where can i make this changes? Or qhat am i missing? Thanks
- April 2013
January 2, 2014 at 7:34 am #517109As I can see that in both pages:
Blog view page: http://www.colegioddinis.pt/cdd/oferta-curricular
and Homepage:
CSS is loaded correctly in ja-botsl2 block. If that’s not what you’re mentioning, pls send me screenshot of how you want to achieve, I will help you out.
jcnr Friend
jcnr
- September 2010
January 2, 2014 at 12:17 pm #517152Hello Nazario A
So weird, yesterday was not like that, well maybe a stupid mistake on my end regarding cache cleaning.
And so very sorry for wasting your time on a non-problem.
Viewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 3 voices, and was last updated by Nazario A 10 years, 11 months ago.
